čínske autorádio- Root
AnoNym1337
Dátum registrácie: 02 Jún 2016, 17:15
Vek: 24
Príspevok od používateľa AnoNym1337 » 07 Máj 2020, 09:18
Zdravíčko, kúpil som čínske android autorádio Model SWM 9702. Je to fake android 8.1 reálne je to 6.0. potreboval by som toto rádio rootnuť nakoľko je tam veľa zybtočných procesov ktoré to len spomaľujú (ako každý android) a ešte spojazdniť 3g Usb modem huawei e173 mam na to appku ppp widget ale vyžaduje root tiež.
no asi takto skusil som toto
kingo root
iroot
a kopec podobných xy-root.apk súborov ani jednému sa nepodarilo nič spraviť
ďaší napad tu bol od jedného pána z levíc na XDA developers ktorý napísal toto ako návod
Instructions
Prepare:
- download and unzip archive from my first post
- make/buy USB A male to A male cable (for photos see attachments)
- install drivers from SP_Driver folder
Backup:
Just in case make backup (readback in ATC Flash Tool)
I didnt done it, so if u want, search for guide online
Flashing process:
- open flash_tool.exe from ATC_Flash_Tool folder
- select Download-Agent MTK_AllInOne_DA.bin from ATC_Flash_Tool folder
- select Scatter-loading File AC8227L_Android_scatter.txt from Firmware folder
- make sure PRELOADER is not checked. (There isnt any in in my fw. Just in case if u use this guide for some another fw)
- press Download button
- connect your USB A to A cable one side to PC, another one to your head unit. I recommend u to use that 4 pin usb port (that one with smaller plastic end), but shouldnt matter.
- press RST button on your head unit (use some pin, paper clip or toothpick)
-wait until flashing process ends. There should appear green message.
- press RST button again and let yout headunit boot.
- perform factory reset on your head unit to prevent any bugs
Flashing process error:
- happends sometimes
- disconnect your cable
- if possible, disconnect your head unit from electricity for a while
- press download again, connect usb cable back, and press RST button.
- check if your cable is not faulty.
- for homemade cable try to apply some solder on cable ends, check if ends arent shorted, use tape on them, or buy original cable
nainštaloval som všetky veci do pc stlačil download na flash tool zapojil usb do radia a do pc (skusil som viac slotov)
no po stlačení reset radia sa nestane nič normalne sa resetne a nabehne. flash tool ani nezaznamená nič.
v podsate by sa mi stačilo dostať do recovery menu no ten neviem ako spustit lebo na kazdom radiu je to skoro rovnako ale zaroveň ináč skusím som asi 5 roznch reštratov do recovery modu, ďalej som sa pokusil stiahnut nejaku appku ktorá ma reštartne do toho recovery modu ale zas ta app potrebuje root a tým padom je to začarovaný kruh alebo je nejaká ktorá nepotrebuje root ? Ďakujem
Edgar
Vek: 27
Re: čísnke autorádio- Root
Príspevok od používateľa Edgar » 07 Máj 2020, 11:06
Tak náhodou Android nepodporuje 3G modemy natívne? Kedysi som mal tablet s Androidom 4.2 a keď som cez OTG redukciu pripojil HUAWEI E3131 tak sa mi hneď objavili v nastaveniach mobilné dáta a aj hore ukazovalo signál, proste normálne ako keby to bol tablet so SIM kartou.
AnoNym1337
Vek: 24
Príspevok od používateľa AnoNym1337 » 07 Máj 2020, 11:43
práveže nie nech skúšam jak skúšam na pc to ide normalne ten 3g modem no na radiu vobec
kako
Dátum registrácie: 07 Mar 2014, 06:38
Príspevok od používateľa kako » 07 Máj 2020, 12:43
ten reset držíš stále? alebo len stlačíš?
Mal by sa držat počas celeho flashovania
alebo stlacit držat a pripojit napajanie
ho
AnoNym1337
Vek: 24
Príspevok od používateľa AnoNym1337 » 07 Máj 2020, 12:57
pokial držím reset tak radio sa ani nespustí
kako
Príspevok od používateľa kako » 07 Máj 2020, 12:58
ked drzis, flashtool nezistí COM port?
ho
djwiktor
Dátum registrácie: 01 Júl 2010, 00:00
Vek: 36
Príspevok od používateľa djwiktor » 07 Máj 2020, 16:15
NA jednej cinskej sra*ke ktoru som davnejsie flashoval bolo treba mat to radio zapnute normalne, a potom dat download , pripojit USB kabel a musi sa pripojit ako comport. potom zmacknut a pustit reset a malo by to ist. ak to nepojde, hodit do kosa alebo pouzivat tak ako je, lebo az s tym zacnes laborovat, tak to bricknes a vlastne potom to mozes uz iba hodit do kosa.
Tlacim na 3D tlaciarni Felix 3.0 dual
Stormchasers.sk
AnoNym1337
Vek: 24
Re: čínske autorádio- Root
Príspevok od používateľa AnoNym1337 » 07 Máj 2020, 17:48
ani tak ako písal djwiktor to nefunguje. nieje nejaký overený root ako appka ktorá funguje ? asi pochybujem
alebo som čital že debug cez wifi ale na to treba ten root
ešte som zistil že vnutri na radiu je asi na firmware RX,TX a GND len neviem či by to cez to šlo
